Kevvx6
Jul 06, 2021Follower
Ping spike problems
Alright so ive been having this problem for a while but man im fed up with it. So a few months ago i built my pc and was using the atnt router through ethernet and man the wifi was perfect, no ping s...
michaelkenward
Jul 07, 2021Guru - Experienced User
Kevvx6 wrote:
Im getting 5ghz of wifi and my ping stayed somewhat the same but ive started getting so much lag spikes now, its like every 10-30 seconds i get at least one lag spike, im honestly lost on what to do and need the help man i cant really take it anymore.
If this is the main point of your message, hard to tell, I find it difficult to understand what you are doing and what the problem is, but I do know that this isn't the best place to ask for help with the EX7000.
You have posted your message in the section of this community given over to Nighthawk WiFi Routers. (This is easily done, given Netgear's complicated community structure.)
Many questions apply to different types of device, so there may be useful responses here, but you might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
WiFi Range Extenders & Nighthawk Mesh - NETGEAR Communities
I will ask the Netgear moderator to move your message.
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
You may have done this already. I can't tell from your message.
I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
