Rosy2021
Nov 24, 2021Initiate
Planet or global icon is orange on my router AC1000 model 6080
My router was working fine last night ( I did have Internet ) this morning not Internet and the global icon is orange now, we call our internet provider and they said that everything coming from their...
Nov 24, 2021Guru - Experienced User
what modem/gateway is the router connected to?
Your ISP says its works, did you check it? Power off the modem/gateway and direct connect a pc/laptop to it.
- Rosy2021Nov 24, 2021InitiateI will check when I get back home and let you know. Thanks
- michaelkenwardNov 25, 2021Guru - Experienced User
The orange globe icon says you have no Internet connection between router and modem.
First reboot your network.
- Turn off and unplug modem.
- Turn off router and computers.
- Plug in and turn on modem. Wait 2 minutes for it to connect.
- Turn on the router and wait 2 minutes for it to connect.
- Turn on computers and rest of network.
That has restored may connection without any real effort.
By the way, 6080 is probably R6080. If your Internet runs faster than 100 Mbps, you may be throwing away a lot of speed. The R6080 is Netgear's basic router with 20th century network technology.
