ThomasAppel
Feb 25, 2021Aspirant
Playing Counter Strike (CSGO) it shows I am from Poland but I am from Denmark.
Hi Playing Counter Strike (CSGO) it shows I am from Poland but I am from Denmark. Also I got a notification from Microsoft that I was logged in from Poland. When I change to use a mobile hotspot the...
ThomasAppel
Mar 06, 2021Aspirant
Has tried to factory reset the router and install it again but i still face the same issue. Poland is not the nearest CSGO server and if I join from another network there is no problem. Same issue with WIFI and network cable. On my old R7000 router there was no problem. The provider has changed the fiberbox to run in bridgemode but that does not either solve the it.
DarrenM wrote:Is Poland the closest CSGO server? You may want to pull the power on the modem and the routers and restart the PCs this seems like a strange IP issue since your not using a VPN.
DarrenM
DorothyMorgan
Apr 07, 2021Aspirant
Also had this problem
