coolcatco888's avatar
coolcatco888
Please add support to R7300 DST to enable Bridge Mode & Repeating Mode
I want to extend my wireless network from my main router (Netgear R7000) to another router I have on hand, a Netgear R7300 DST. They both seem very similar, however, I just noticed that the R7300 DST...
  • plemans's avatar
    Jan 02, 2023
    Then you're a little screwed as the R7300dst is an end of life product. And if there isn't any 3rd party firmware for it, there isn't much for changes.
    You could connect it using its powerline connection?
    Or even just hardwire it in with ethernet
