SpunkySpank's avatar
SpunkySpank
Please Help! Nighthawk XR300 Pro Gaming Router - DumaOS
I have been trying to portforwerd a game server for a cupple of days and I believe my router may have a glitch thats stopping my port from sending and possibly receiving information.
This problom starter after the router was factory reset.
I am using Windows 10 but i also have Xubuntu available, the game I was initially trying to port for is Conan Exiles after disabled the firewall in windows the conection started showing on the steam server list but no one could connect, after that I set myself as the DMZ and gave my self a stagnant IP witch changed nothing, I also tested the connection with a mincraft server we were able to connect but the other players couldent see anything they where just in a void, im asuming only i could see things becuase I was running the server on the same pc I was connecting with, I tryed agin in Linux witch gave the same problem, so I believe the ports are for some reason not sending the information through.
Dose anyone know any possible fixes?
