Tuchay
Feb 16, 2022Follower
Please help
Hello I need help involving some doSs attacks and ACK scans. Im not sure on what I can do , im not sure if i am being attacked so i need help to find out if i am please. My 90 day thing has been up f...
michaelkenward
Feb 17, 2022Guru - Experienced User
Is this because you see reports in the router's logs?
Netgear's firmware is great at creating false reports of DoS attacks. Many of them are no such thing.
Search - NETGEAR Communities – DoS attacks
Use Whois.net to see who is behind some of them and you may find that they are from places like Facebook, Google, even your ISP.
Here is a useful tool for that task:
IPNetInfo: Retrieve IP Address Information from WHOIS servers
If these events are slowing down your router, that may be because it is using up processor time as it writes the events to your logs. Anything that uses processor power – event logging, QoS management, traffic metering – may cause slowdowns. Disable logging of DoS attacks and see if that reduces the problem. This does not prevent the router from protecting you from the outside world.
