chiyeji
Dec 07, 2023Follower
Please, need help with my Nighthawk R700P, Orbi AX400 Mesh Wi-fi, and AC1900 Wi-fi Extender setup
My devices are: AT&T Modem (ISP provider) ---2.4 GHz WIFI & 5 GHz WIFI operation both disabled. (someone said you can disable the router mode of the AT&T modem and just let it handle o...
michaelkenward
Dec 07, 2023Guru - Experienced User
chiyeji wrote:
- AT&T Modem (ISP provider)
---2.4 GHz WIFI & 5 GHz WIFI operation both disabled. (someone said you can disable the router mode of the AT&T modem and just let it handle only "modem" stuff. is this true?)
Possibly. But turning off the wifi doesn't do it.
Find the make and model of your modem. Search the internet for:
"[your model number] bridge mode"
Read and digest.
