Isaac2156
Jan 06, 2022Aspirant
Please tell me if the NETGEAR Dual-Band AC1200 is worth it
I just wanted to know if this is worth it and if it has great speeds and such. I don't think I chose the right model, so I'll provide this.
Jan 06, 2022Guru - Experienced User
IF thats something that you feel fits your home networking needs and you don't need anything more then that, then it would work.
All kind of depends on what your doing at home, streaming, downloading, gaming, simple internet crawling and how many devices you have. If you want to future prooof, then this router wouldn't be a good fit as its getting up in age being on the market. You may want soemthing a bit newer.
Netgear has set up a community forum specifically for Smart WiFi Router products:
https://community.netgear.com/t5/General-WiFi-Routers-Non/bd-p/home-wifi-routers-general
Thank you
