DarrenM
Jan 21, 2025Sr. NETGEAR Moderator
Please update your R6400v2, R6700v3, R7000, R7000P, R7960p, R8000, R8000P as soon as possible
| Required Security Firmware Update |
| Hi , |
| NETGEAR strongly recommends that you update to the latest firmware version for your as soon as possible. |
| A Firmware update was released on that addresses security vulnerabilities, however your has not been automatically updated and is running a firmware version earlier than . |
| Please follow these instructions to update your product to the latest firmware version using the Nighthawk app: |
| Alternatively, if you run into any issues updating your router's firmware using the app, please see How do I update the firmware on my NETGEAR router with a web browser? |
| The file that will need to be uploaded is: Firmware Version 1.0.12.216 Download. . This file is for the R7000 if you have another model please check out the support site here. Then type in your router model to get the latest firmware. Once you click, the file will automatically download. Tip: Note the downloaded file location. |
| NETGEAR continually monitors for both known and unknown security threats. Our proactive approach is fundamental to earning and maintaining the trust of our customers who rely on NETGEAR products for secure and reliable connectivity. |
| We recommend keeping your NETGEAR products up to date with the latest firmware. Firmware updates contain important security fixes to help protect against new and evolving threats. |
| NETGEAR Security Team |
