gonse
Oct 23, 2019Star
Plex Media Server not working after updating to V1.0.5.2
After updating to firmware V1.0.5.2, the router is not able to download the latest plex version 1.18.0.1913-e5cc93306 (strangely enough, it says that the release date for that version is Jul 16, 2019...
- Oct 25, 2019
This issue should be resolved now please try to remove the Plex update and reinstall it.
DarrenM
schumaku
Oct 23, 2019Guru - Experienced User
Same here, unticked the automatic update, and select Update now - zero indication in the router Logs (not the first time) ... wonder what logs are for?
| Plex Version Update |
| Enable Automatic Plex New Version Update |
| Current Plex version: 1.16.3.1402-22929c8a2 Jul 16, 2019 |
| New Plex version: 1.18.0.1913-e5cc93306 Jul 16, 2019 |
| Unknow error. |
- schumakuOct 23, 2019Guru - Experienced User
Not kiding: Unknow error.
Fits to the missing spaces in the pop-up:
If you proceed with the update, your Plex Media Server will restart.Do you want to continue with the update? Chinglish or Hindish?
- gonseOct 24, 2019Star
Netgear are you going to fix this issue? Plex Media Server (a key feature of this router) IS UNUSABLE, or should I start setting my mind on "build another PMS dude, this is gonna be a long ride" mode.
The problem is with the PMS release and not the firmware update, because before I updated the router firware I wasn't able to download the new PMS version.
