softerist
Jul 03, 2020Apprentice
Plex Media Server not working on Nighthawk X10 R9000 Router Firmware Version V1.0.5.18
Hi. Today you released new update but this broke the Plex Media Server. Can you please fix it? See picture attachment. Also the telnet on debug.htm it's no longer available, why? Thanks! ...
- Jul 08, 2020
Hi guys.
I've managed to reinstall/plex by doing the following:
0) Disable donwload/enable Plex and update checkboxes on you router page.
1) I've installed a web server (in my case Microsoft IIS)
2) I've added this file to the web server and made it accesible via HTTPS at this address (https://localhost/sw-apps/plex/r9000/verify_binary.txt), with some certificate, doesn't matter what certificate, just place one for HTTPS connection to became accesible - in my case I've used one installed already in my personal cert store named NVIDIA GameStream Server.
3) go to router telnet, then login via telnet
4) edit /etc/hosts and add this line, where 192.168.1.2 it's my newly webserver:
192.168.1.2 http.fw.updates1.netgear.com
5) Type this to make sure that old/bad arhive it's deleted:
rm -rf /var/plexmediaserver-r9k-1.19.4.2935-79e214ead-armv7.tgz
6) go to:
cd /var
7) Enable Plex Media Server
Proof attached.
Special thanks for tips to: kc6108
Mahuka
Jul 08, 2020Aspirant
Was this fix done on latest firmware or previous version? I was unable to find the manual option referred to "(thus revealing the manual "update" option for Plex in the router GUI)" I also looked into HTML code but didn't see it hidden there.
-SC
softerist
Jul 08, 2020Apprentice
Hi Mahuka.
If you want to just update from an older version to the newest just follow kc6108's instructions.
If you want to install/reinstall from scratch follow my above instructions.
- gonseJul 08, 2020Star
Same issue here, and no idea how to enter the router via telnet.
Netgear took 6 months to solve an issue that basically broke the NAS functionality.
No idea how long it will take them to solve this.
- MahukaJul 09, 2020Aspirant
Follow kc6108 instructions above for enabling telnet. You have to ensure telnet is enabled on your windows machine as well. Then use
softerist instructions to perform a scratch install of plex. It took me about 10 minutes to fix it but I am familiar with telnet, IIS, etc.. may take some learning otherwise - SaniaJul 10, 2020Initiate
In case you couldn't enable telnet as described by kc6108 , you can always downgrade the firmware to V1.0.5.8, access routerlogin.net/debug.htm, check the “telnet” option and perform the rest of the steps to update the PMS. After that, you can upgrade the firmware back to V1.0.5.18. It will not affect the updated PMS.
- gonseJul 11, 2020StarThank you! That did the trick.
