rayjrh80
Jul 21, 2018Tutor
Plex on nighthawak r7000
Im trying to run my server on my night hawk r7000, but my plex on my PC cannot connect using the night hawk router. I tried adding port forwarding to 32400, but still cannot connect. Please help?
- Jul 21, 2018
I was able to make it work on my netgear r7000. I was at first port forwarding to 32400, but that would not work. So then I disabled the port forwarding and tried port triggering to 32400 TCP. After I changed the settings I rebooted my router and it worked. Now I can stream Plex from my PC.
schumaku
Jul 21, 2018Guru - Experienced User
Plex can only run on the R9000 and it's little brother, the R8900. If operating Plex Media Server on the R9000/8900 of course, there must be no port forwarding in place for 32400/TCP - it's rechable on the LAN and on the Internet/WAN interfce on the very same port. Anything else migth cause issues.
Or do you run a R7000 and Plex on the PC only, and need a port forarding to be able to rech the Plex Server on the PC from the Internet?
In either case, more insight must be provided - the crystal ball is on summer holidays.
- rayjrh80Jul 21, 2018Tutor
Im running plex on my PC not on the router. I was able to fix the issue. Thanks
