rayjrh80
Jul 21, 2018Tutor
Plex on nighthawak r7000
Im trying to run my server on my night hawk r7000, but my plex on my PC cannot connect using the night hawk router. I tried adding port forwarding to 32400, but still cannot connect. Please help?
- Jul 21, 2018
I was able to make it work on my netgear r7000. I was at first port forwarding to 32400, but that would not work. So then I disabled the port forwarding and tried port triggering to 32400 TCP. After I changed the settings I rebooted my router and it worked. Now I can stream Plex from my PC.
aabshire
Jul 21, 2018Apprentice
I had this issue a couple of times. If I recall I went into plex and either changed the port # and then changed it back (saving each time) or disabled/reenabled it.
- rayjrh80Jul 21, 2018Tutor
