rayjrh80's avatar
Jul 21, 2018
Plex on nighthawak r7000
Im trying to run my server on my night hawk r7000, but my plex on my PC cannot connect using the night hawk router. I tried adding port forwarding to 32400, but still cannot connect. Please help?
  • rayjrh80's avatar
    rayjrh80
    Jul 21, 2018
    I was able to make it work on my netgear r7000. I was at first port forwarding to 32400, but that would not work. So then I disabled the port forwarding and tried port triggering to 32400 TCP. After I changed the settings I rebooted my router and it worked. Now I can stream Plex from my PC.
