Garyleetoo
Aug 23, 2022Tutor
Poor Support
I've worked with six plus techs, for over 7 months, on multiple issues with my R7000P Nighthawk, with no progress what ever. I've written two letter to the CEO's office with no responses. How do I ...
Aug 23, 2022Guru - Experienced User
What issue are you running into?
Some of it might be the fact that it was released in 2016 and while isn't considered end of life, isn't getting much for updates.
Most updates are just security related.
You can always check into 3rd party firmwares for that device. I've heard good things about modifying it. (does void warranty)
