Garyleetoo
Aug 23, 2022Tutor
Poor Support
I've worked with six plus techs, for over 7 months, on multiple issues with my R7000P Nighthawk, with no progress what ever. I've written two letter to the CEO's office with no responses. How do I ...
michaelkenward
Aug 24, 2022Guru - Experienced User
Garyleetoo wrote:
How do I get help with these issues that should have been resolved.
Start here.
According to the community, some have existed since inception of this product.
Care to point us to some of those messages? It might help to advise you on what causes grief at your end.
I have used an R7000P since it was released, more than five years ago. Hardly a problem in sight. Just keeps soldiering on.
- GaryleetooSep 18, 2022Tutor
1) VPN won't work
2) 5G quits id MIMO is on
3) adding a new device to the network takes a restart to be noticed, or one has to wail hours or even days to be noticed.
4) The Circle add comes up at even logon and can't be disabled.
I've tried one R6900P and and two R7000Ps, all had the same issues.
Netgear has been working on these issues since March and has resolved none of them.
I've written three letters to the CEO and received zero responses.
- FURRYe38Sep 19, 2022Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.What channels are you using? Auto?
Any Wifi Neighbors near by? If so, how many?How is advanced Wifi Settings configured on the router?
- GaryleetooSep 27, 2022Tutor
I have all Belden Cat 6 wiring; I'm an ex-network guy, but retired for over 15 years and have been using Netgear, exclusively, for almost 30 years. I have cover 25 connected devices, most wired, and use subnet 0.X not the default 192.168.1.X. Netgear's higher tier, has been working on the issues for months. I live in the mountains; I use inSSIDer; to verify that Ihave no close or interfering neighbors. I have FW V1.3.3.148_10.1.82 Using channels 1 & 157 with WPA2 security (PDF Attached), and access control via MAC address. I use a Windstream T3260 Router, in bridge mode, with 12G bonded DSL service. .Thanks for you interest and support.
