JohnNadeau
Jan 20, 2016Apprentice
Poor Throughput with Netgear GENIE Running
I'm posting this under the Fireware Label with this in mind: Is it possible that those experiencing Throughput problems after a firmware upgrade are running the Netgear Genie Windows Application? ...
- Jan 20, 2016
There used to be a ton of posts, of exactly what you were describing. Poor performance. User would remove that app, and all would be good..
JohnNadeau
I guess "gluton for punishment' comes to mind :smileyembarrassed:
I like the NetWork Map with the ability to assign meaningful names and icons to each device... and was experiementing with some of the other features.
I use the web interface primarily. Access Control gives the ability to assign meaningful names, but not icons.
More importantly, just wondering if other users suffering from poor throughput would try turning off the Genie Application and see better performance.
netwrks
Jan 20, 2016Master
- JohnNadeauJan 20, 2016Apprentice
Good to know. Thanks!
