roboto120
Nov 14, 2021Aspirant
Port 80 is closed on CAX30
Hi, I'm trying to forward port 80 from my CAX30 modem to my laptop and it is not working. I was able to forward ports 443, 18080, etc. but for some reason port 80 doesn't work. I don't have any A...
- Nov 14, 2021
Ok, this worked after I rebooted the modem a couple of more times. Seems to be working consistently, so closing the thread.
Nov 15, 2021Guru - Experienced User
Netgear has set up a community forum specifically for the Cable Modem products. Most of the people who watch that forum are more likely to have experience with Cable modems and know how to work it better than those of us who follow this router forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Cable-Modems-Routers/bd-p/home-cable-modems-routers
Thank you.
