SandyStow
Jul 26, 2022Aspirant
Port 8883 block on X6 R8000 Router
How can I unblock port 8883 Cox says it is because of my router I am trying to install a garage door opener with Amazon Amazon says that port should be open I have a nighthawk X6 R8000 Router
Jul 26, 2022Guru - Experienced User
Try Port Forwarding? https://kb.netgear.com/000053857/Enable-Port-Forwarding
- SandyStowJul 27, 2022Aspirant
I am trying to get my Amazon garage door opener to work.
Its a smart garage control - It's called a My Q
Sorry, I am not tech smart. đ
The My Q support person had me go on
Ismyportopen.com
I entered port 8333 and it was block. She said I should call Cox and have them open the port
I called Cox - The said they do not block the port. My router was blocking that port
- FURRYe38Jul 27, 2022Guru - Experienced User
What happens if you put the IP address assigned for this device into the routers DMZ?
