godeepdown
Jan 16, 2021Aspirant
port blocked
I am running a CM700 modem and a R6400-v2 router and need to have access to port 8883. If i run a check it says it is blocked. I called Comcast and they say it is not on their end and I need to talk ...
godeepdown
Jan 17, 2021Aspirant
I have followed all the instructions on Chaimberlains website for the hub and for my router and was walked through them again by their tech support person. I have tried to reconnect at least 50 times. Factory reseting the hub at least 10 times uninstaling and reinstalling the app. My 2.4 network is woring fine all other devices connect with no problem. I connected to the modem directly just to see if the router was where the issue was with port 8883. I understand that the port is not the issue if I can not connect the hub to the router but their tech support says that is the problem and I cannot get them to go any further since they are blaming the port and not willing to look further at the hub. I would love to forget about the port but they will not. According to them it is either the port or I do not know my password.
Ports Required for myQ Products to Communicate with the myQ Server
- Verify inbound and outbound TCP port 8883 is open
- Verify the port is not being blocked by your router or a firewall product
Went through all the router settings at the page above as well
The hub does not appear as an attached device and I do not expect to forward the port, I put that in so someone did not tell me to forward the port.
godeepdown
Jan 18, 2021Aspirant
Said screw it bought a new hub and it connected right away. The original hub must have failed.
