mwdmwd
Jun 25, 2016Aspirant
port blocking issues with X8 (UDP, TCP)
Hi. First time posting. I need to confirm that the X8 is not set to block certain UDP ports (37, 123) or TCP ports (37, 80, 443, 5005, 5222, 5223, or 7287). I've looked through the routerlogin.net me...
- Jun 29, 2016
Hi mwdmwd,
Cana you access those ports on your modem? If yes and not on router, you may need to do port forwarding for those port numbers in router.
mwdmwd
And of course, in the way that only after posting to a message board does something become clear to me, I now realize I need to look into my modem, not my router, most likely.
- JamesGLJun 29, 2016NETGEAR Employee Retired
Hi mwdmwd,
- JamesGLJul 11, 2016NETGEAR Employee Retired
Hi mwdmwd,
We’d greatly appreciate hearing your feedback letting us know if the information we’ve provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!
