mwdmwd's avatar
mwdmwd
port blocking issues with X8 (UDP, TCP)
Hi. First time posting. I need to confirm that the X8 is not set to block certain UDP ports (37, 123) or TCP ports (37, 80, 443, 5005, 5222, 5223, or 7287). I've looked through the routerlogin.net me...
  • JamesGL's avatar
    JamesGL
    Jun 29, 2016
    Hi mwdmwd,
    Cana you access those ports on your modem? If yes and not on router, you may need to do port forwarding for those port numbers in router.
