bayhuntr
Feb 07, 2016Tutor
Port Forward stopped working on WAN, but not LAN... Around same time as last update.
Port are set up to access IP cams and the Blue Iris server. I can access them from within the network, but not from out side. From outside I try both IP and name. I've varified my DNS is corect. I...
- Feb 15, 2016Your advice would have solved one of the two problems, but it would've been the hard way to resolve it, as opposed to just reentering the port forwarding. Using the upgrade wizard, failed to notify us of the port forwarding issue. This was pore planning on Netgear part.
The second issue, devices dropping at random times throughout the day, my Amazon echoes randomly losing connection, iPhones losing connection, WeatherStation losing connection, all of these issues resolved by turning off the new feature, Ario, that you added to the router, and default it on.
This software upgrade was botched, perhaps you can test more thoroughly before you release the next one?
netwrks
Feb 07, 2016Master
Reset to factory default and reconfigure from scratch or fall back to your previous version of firmware.
