Skip_007
Jun 24, 2016Aspirant
Port Forwarding - 2 PCs
My wife and both play LOTRO and it seems that there is a requirement for port forwarding. The question that I have revolves around the fact that there are 2 computers involved. Is it possible to forw...
- Oct 25, 2016
Hi kokeysian,
I believe that your router was supplied by your ISP based on the firmware version (CH suffix) that you have provided. Please check with your ISP if there are any updates or if this is something the can fix since the retail versions do not have this issue.
Dexter
Community Team
kokeysian
Oct 24, 2016Aspirant
i did do that. i am opening different external ports but forwarding it tot he same port but for two different internal machine :)
DexterJB
Oct 25, 2016NETGEAR Moderator
Hi kokeysian,
Dexter
Community Team
