machine_74
May 19, 2021Guide
Port forwarding 3389 through Nighthawk R7000P to Deco wifi
I have a machine using Plex that works much better on our mesh wifi. The issue I have is that I have that machine available viaDeco Port 3389 for RDP offsite. If I put the machine on the wifi, if ge...
- May 19, 2021
> [...] our mesh wifi. [...]
Not a very detailed description. Maker? Model number?
> [...] my Nighthawk R7000P [...]
Which is connected to what, how? (Hint: If a device has different
types of ports, then "connected to device" is not enough detail.)Where does your ISP connection (modem, ONT, ...) come into this mess?
> [...] If I put the machine on the wifi, if gets an IP that my
> Nighthawk R7000P router can't use for port forwarding.A few actual IP addresses might have made that more helpful.
> I've tried setting up port forwarding through the wifi's app but no
> dice.
"I've tried" or "no dice" is not a useful problem description. It
does not say what you did. It does not say what happened when you did
it. As usual, showing actual actions (commands) with their actual
results (error messages, LED indicators, ...) can be more helpful than
vague descriptions or interpretations.Generally, to avoid such IP address problems (as I assume you're
seeing), you want one router, not two. I'd guess that whichever router
is currently closer to your ISP is the one which you should leave as
your router. The other router should be configured as a wireless
access point. Presumably, the manual for that router will explain how
to do that.For a Netgear router, visit http://netgear.com/support , put in your
(actual) model number, and look for Documentation. Get the User Manual
(at least). Read. Look for "access point".That way, all your client devices should get IP addresses on the same
subnet, and you should be able to configure port forwarding (on your
remaining router) without such problems.
Also, I would advise against using a well-known port like 3389
externally, unless you _want_ to be attacked from every malware-infested
Windows system on the planet. For suggestions for a more discreet
configuration, see, for example:
antinode
May 19, 2021Guru
> dice.
to do that.
- machine_74May 22, 2021Guide
I mentioned i have the Deco wiri mesh, and what I did was make them access points and not routers themselves dishing out a different IP scheme. The Android app defaults to NOT APs for some reason. Their equipment has a limited number of ports and it made more sense for everyone to have everyone be on the same subnet. Once I did that worked great, as well as changing my port.
Now my issue is with the wifi card itself, so I'll start another topic. Keeps dropping connection every 10s. Thanks for your input.
