Str_Platinum
Dec 11, 2021Aspirant
Port Forwarding a Minecraft server WNDR4500v2: Firmware Version V1.0.0.72_1.0.45
Hello, I have been trying to set up a Minecraft server but it only works with my PC that's connected to my Netgear router (I've asked others outside of my house to try to join). Also port checkers s...
Dec 12, 2021Guru - Experienced User
Be sure to mark your thread solved so others will know.
Netgear has set up a community forum specifically for General Router products. Most of the people who watch that forum are more likely to have experience with older routers and know how to work it better than those of us who follow this router forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/General-WiFi-Routers-Non/bd-p/home-wifi-routers-general
Thank you
