stefy97100's avatar
stefy97100
Port forwarding doesn't works
Hi, i've bought the Netgear d7000 Nighthawk but when i try to configure the port forwarding it doesn't works. In lan if I visit the link/address 192.168.1.251:81 on a browser the server response with the webpage but if I try to access from publicip:81 it doesn't works.
This is my configuration: http://i.imgur.com/bdnooxz.jpg
I have the same problem using port 80. Only DMZ works.
1 Reply
