Brettster's avatar
Brettster
Port Forwarding for Netgear Router R6700v2 is timing out/not working
I have a R6700v2 router that I was trying to setup to allow port forwarding for ssh access to my home Mac. My home Mac is accepting ssh (port 22) locally. I confirmed this by running 'ssh username@localhost' on Terminal which allowed me to connect to it.
In my attached screenshot, it shows that I have Port Forwarding turned on for connections externally at port 22 and being forwarded to port 22 at my Mac's local address of 192.168.1.6. When I use terminal to test this and put 'ssh username@ExternalIP' the connection times out. I also have No-IP creating a dynamic DNS for me, but since I'm using the ExternalIP to test it that shouldn't be the problem either.
TLDR: I've ruled out these common trouble shooting problems:
  1. Mac is not listening at port 22 (I can ssh locally, so that's not the case)
  2. Dynamic DNS is not working (I'm not at the step of using it, so that's not the case)
  3. Port check tool times out as well (confirms that the problem is specifically related to the router)
Where am I going wrong? Is this a hardware issue? If I can help clarify then I would be more than happy to do so. Thank you!
  • > Different... interesting
       Even worse than interesting.  Fill in your actual address, if you
    want, but the result will be the same:
          https://whois.arin.net/rest/net/NET-10-0-0-0-1
    > [...] Is this where my problem lies?
       No, it's not a DNS problem.  Welcome to carrier-grade NAT.  From the
    outside world, your router appears to be at "184.170.x.y", but your
    router is really at "10.238.u.v", which is a private address, used by
    your ISP.  Your ISP is doing its own NAT, to let it use "184.170.x.y" (a
    real public address) for multiple customers.
       Because any "10.r.s.t" address is considered private, any router in
    the outside world will discard any message which is addressed to your
    router at "10.238.u.v".
       This NAT is the same thing as the NAT on your router, which lets
    multiple devices on your LAN share the one IP address assigned to your
    router, except that your ISP is doing it, and it's out of your control.
    So, anything you read about "double NAT" applies to you, except that
    your outer router is controlled by your ISP.
       Sadly, that also means that port forwarding (like what you want to
    do) must be configured on the ISP's NAT router (as well as yours, I'd
    guess, but I've never tried that).
       The only solutions I know are: 1) to ask your ISP for a real public
    address, or 2) to use a tunneling service like the one mentioned in
    another recent thread (near the end):
          https://community.netgear.com/t5/x/x/m-p/1748431
  • > 3. Port check tool times out as well (confirms that the problem is
       No, it doesn't confirm that, it's only consistent with it.  As it is
    with many other non-router problems.
    > [...] I confirmed this by running 'ssh username@localhost' [...]
       A better test would be "ssh 192.168.1.6".  "localhost" is normally
    resolved to "127.0.0.1", which does not ensure that your Mac is at the
    address in your port-forwarding rule.
       What is your public IP address? ("a.b" of "a.b.c.d" would be
    enough for me.)  What is the WAN/Internet IP address of your router?
    ADVANCED > ADVANCED Home: Internet Port : Internet IP Address.  Same or
    different?
       A test like "ssh <router's_WAN/Internet_IP_address>" should tell you
    if the router is doing its port-forwarding job correctly (assuming that
    its "NAT loopback" feature is also working, but I'd expect that).
       The usual problems with this stuff are:
       1. Wrong external IP address (different from the port-forwarding
    router's WAN/Internet IP address).  (An intermediate NAT router, for
    example, could cause this.)
       2. Bad port-forwarding rule (wrong port(s), wrong target address --
    including a wandering target).
       3. Server not listening on the port-forwarding target system.
       4. External influences: ISP blocking, other firewalls, ...
       You seem to have 2 and 3 covered, _if_ the Mac's LAN IP address is
    right in the port-forwarding rule.  ("Address Reservation?)  "1" tends
    to cause increasing trouble these days, as ISPs run out of IPv4
    addresses, and resort to carrier-grade NAT.
          https://en.wikipedia.org/wiki/Carrier-grade_NAT
       Regarding External Port 22: It makes much sense to configure SSH on
    your local servers to use the default SSH port, 22.  However, unless
    you're looking for a bombardment of SSH break-in attempts, it makes
    almost no sense to use port 22 on your WAN/Internet interface.  A rule
    like the following will, I claim, save you considerable annoyance:
        Protocol   External   Internal   Server IP Address
        TCP/UDP      2022         22     192.168.1.6
       This does mean that you'd need to add "-p <port>" to all your
    outside-world SSH commands, but it's a small price to pay.  (Pick any
    memorable port which is not needed for some other purpose.)
    > In my attached screenshot, [...]
       24KB of picture to show 100 characters of text?  Copy+paste is your
    friend.
    • Brettster's avatar
      Brettster
      different?
      Public: 184.170 (a.b)
      Netgear Internet IP Address: 10.238 (a.b)
      I can ssh using the Netgear Internet IP Address... but when I change my No-IP Dynamic DNS to that address it times out... so I'm quite confused by that. Would this mean netgears integration with no-ip dynamic dns not work in this scenario since it would be reverting to the public IP and not the Netgear Internet IP Address? Is this where my problem lies?
      External Port 22, Once I get the port forwarding working 100%, I was going to change it. I hadn't changed it to make troubleshooting a little bit easier, but I appreciate the valuable information.
      I appreciate all the help, and if there's anything I can do to give more information, please do let me know.
      • antinode's avatar
        antinode
        Guru
