shawntanamobay
Jul 12, 2021Follower
Port forwarding is programmed but when i check they are closed
I'm trying to open up ports for my PS5 for Playstation Network
PSN says i need to open the following ports:
TCP/UDP 1935, 3074, 3478-3840
or
TCP 1935, 3478-3840
UDP 3074, 3478-3479
I...
antinode
Jul 12, 2021Guru
I can't (yet) see your pictures. In-line images must be approved
by a moderator before others can see them. The time required varies.
Attachments have no such limitation. Of course, attachments have their
own one-per-message limitation.
Thus, I can't see your actual port-forwarding rules, or actual IP
addresses, or any other useful info.
> My setup is a Ubee cable broadband modem [...]
Actual model number?
> [...] I've confirmed with my ISP that my modem isn't a router, [...]
You can ask the router about its WAN/Internet IP address; there's no
need to trust anyone.
For the usual problems with port forwarding, see:
