KaiOsmon
Jun 07, 2016Aspirant
Port Forwarding issues
Wan IP address is 172.103.xxx.xx
1. Did enable "remote management" on port 8843
When I check if the port is open, yes it is. When I go to 172.103.xxx.xx:8843 from my home network I do get...
- Jun 10, 2016
I have figured what it was.
The IP Camera network settings was done properly. The gateway and DNS IPs was left from the previous router. Thats why it did locally but not remotely.
KaiOsmon
Jun 08, 2016Aspirant
I've tried to use NAT filtering with both secured and none, both cases not working. to be honest, not sure what NAT is for.
- Retired_MemberJun 08, 2016
edit I was going to suggest HTTPS in my first response but figured it was obvious
Nat is the function which allows the router to share it's public IP address across multiple devices, leave it alone.
I think a factory default reset is your best option, leave all settings alone except for allow remote connection
