KaiOsmon
Jun 07, 2016Aspirant
Port Forwarding issues
Wan IP address is 172.103.xxx.xx
1. Did enable "remote management" on port 8843
When I check if the port is open, yes it is. When I go to 172.103.xxx.xx:8843 from my home network I do get...
- Jun 10, 2016
I have figured what it was.
The IP Camera network settings was done properly. The gateway and DNS IPs was left from the previous router. Thats why it did locally but not remotely.
KaiOsmon
Jun 08, 2016Aspirant
but I have to do port forwarding for my IP camera. at the very begging, when I didn't touch anything but set pretty forwarding. 8443 was open but my port was still closed
- Retired_MemberJun 08, 2016
try using UPNP it should work unless netgear hosed up this FW version too. Also use address reservations for IP camera
- TheEtherJun 08, 2016Guru
A port forwarding test includes the device at the IP address you are forwarding to. So, make sure your IP camera is on and responsive on that port (1001). Otherwise, the test may appear to fail, even though the router is operating correctly.
