KaiOsmon
Jun 07, 2016Aspirant
Port Forwarding issues
Wan IP address is 172.103.xxx.xx
1. Did enable "remote management" on port 8843
When I check if the port is open, yes it is. When I go to 172.103.xxx.xx:8843 from my home network I do get...
- Jun 10, 2016
I have figured what it was.
The IP Camera network settings was done properly. The gateway and DNS IPs was left from the previous router. Thats why it did locally but not remotely.
TheEther
Jun 08, 2016Guru
Agreed, it's not user friendly. It's not always necessary to reset after a firmware update. It depends on whether Netgear makes a significant change to the configuration. Often it's possible to get by without a reset. But in your case it would be a good idea.
KaiOsmon
Jun 08, 2016Aspirant
Will do it tonight and see if it works, thanks in advance ;)
