KaiOsmon
Jun 07, 2016Aspirant
Port Forwarding issues
Wan IP address is 172.103.xxx.xx
1. Did enable "remote management" on port 8843
When I check if the port is open, yes it is. When I go to 172.103.xxx.xx:8843 from my home network I do get...
- Jun 10, 2016
I have figured what it was.
The IP Camera network settings was done properly. The gateway and DNS IPs was left from the previous router. Thats why it did locally but not remotely.
KaiOsmon
Jun 09, 2016Aspirant
good morning, did hard reset and the action of of no help. remote management port 8443 is open and 1001 still not.
I have been thinking that the problem could be with port numbers and have new port 8441 to remote management and assigned 8443 to IP camera. the result is 8441 is open and 8443 is not... what could be the issue?
- TheEtherJun 09, 2016Guru
So, you changed the setting on the camera to use port 8443 and changed the port forwarding rule to 8443?
Is the port forwarding rule pointing to the IP address of the camera?
How are you testing whether the port is open?
