KaiOsmon
Jun 07, 2016Aspirant
Port Forwarding issues
Wan IP address is 172.103.xxx.xx
1. Did enable "remote management" on port 8843
When I check if the port is open, yes it is. When I go to 172.103.xxx.xx:8843 from my home network I do get...
- Jun 10, 2016
I have figured what it was.
The IP Camera network settings was done properly. The gateway and DNS IPs was left from the previous router. Thats why it did locally but not remotely.
KaiOsmon
Jun 09, 2016Aspirant
- KaiOsmonJun 10, 2016Aspirant
- TheEtherJun 10, 2016Guru
I missed the fact that you used a static IP address on your camera due to another one of your typos. You wouldn't have had this problem using DHCP. Glad you got it working.
