xBumblebee
Oct 18, 2021Aspirant
Port forwarding Nighthawk x8
hello i have trouble with my Nat Typ i have a Fiber 300mb Connection but in Call of duty still nat type Moderate. i opened the NAT Filter to Open and put de adress To the port forwarding and still Moderate.... and watched so manxy videos to change something on the ps4 but nothing wanna work.... when i just put the Modem from my Provider in the ps4 the NAT Type is Open can anyone help me with my prroblem?
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too?- xBumblebeeAspirant
the version of the X8 is V1.0.2.154and the Provider Modem is Genexis Platinum 6820
Your ISP modem already has a built in router and wifi:
https://sedectro.com/product/genexis-platinum-p-6820-standalone-triple-play-router/
This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
1. Configure the modem for transparent bridge or modem only mode. Then use the NG router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ/ExposedHost or IP Pass-Through for the IP address the NG router gets from the modem.
3. Or disable all wifi radios on the modem and connect the NG router to the modem, LAN to LAN configure AP mode on the NG router.
