allredjackson's avatar
Dec 23, 2020
Port forwarding not opening a port
Hello
I am trying to open a port for a server im wanting to run, I have opened up the port forwarding settings and entered all the details as shown on the picture below. Then i have checked to see if said port was open using sites like https://www.canyouseeme.org/ and https://www.yougetsignal.com/tools/open-ports/ neither of them are able to find this port.
So i am wondering if i have set it up wrong or if anyone could help me open said port
Thanks in advance!
1 Reply
  • > [...] i am wondering if i have set it up wrong [...]
       Probably, in a global sense.  To what is your Orbi connected?  The
    fact that its LAN IP address subnet is "10.0.0.*" suggests that there's
    a NAT router between your Orbi and your ISP, which would tend to make
    port forwarding on your Orbi disfunctional, even when done correctly.
       Presumably, if you look at the WAN/Internet IP address on the Orbi, it
    will not match your external/public IP address.
       For the usual problems with port forwarding, see:
          https://community.netgear.com/t5/x/x/m-p/1859106
    Yours, I'd guess, is number 1.
       I see no model number in that picture, only a firmware version.  Is
    the management interface on these things really that lame, or did you
    hide it?
       Note: Orbi-appropriate forums:
          https://community.netgear.com/t5/x/ct-p/home-orbi
