jelmew's avatar
jelmew
Initiate
Feb 16, 2018
Port forwarding not working for port 22 (even though 2200 for examle works)
Hi all,   I am probably just missing something, but port forwarding on port 22 (extern and intern) does not seem to work. If I change the extern port to something else (like 2200) it does work. I h...
  • jelmew's avatar
    jelmew
    Feb 18, 2018
    Hi,
    I solved it. If I only set tcp for external port 22, it works flawlessly. I know higher ports are better, but I'm forced to use this port due to the fact that my work only has a few outbound ports whitelisted. Fortunately, I'm using private/public key authentication and fail2ban, so it is not too bad.
