jelmew
Feb 16, 2018Initiate
Port forwarding not working for port 22 (even though 2200 for examle works)
Hi all, I am probably just missing something, but port forwarding on port 22 (extern and intern) does not seem to work. If I change the extern port to something else (like 2200) it does work. I h...
- Feb 18, 2018
Hi,
I solved it. If I only set tcp for external port 22, it works flawlessly. I know higher ports are better, but I'm forced to use this port due to the fact that my work only has a few outbound ports whitelisted. Fortunately, I'm using private/public key authentication and fail2ban, so it is not too bad.
antinode
Feb 16, 2018Guru
> Model: R7000P|Nighthawk AC2300 Smart WiFi Router with MU-MIMO
Is that accurate? Firmware version?
> [...] port forwarding on port 22 (extern and intern) does not seem to
> work.
What's the failure?
Assuming that your (invisible) port-forwarding rule is correct, then
I'd expect it to work. But, it's Netgear firmware, so many things are
possible.
Years ago, I actually passed external port 22 to an internal port 22,
but there were so many attacks on that port that I changed my external
port for SSH from 22 to something different, and haven't looked back.
That was so long ago that I can't even be sure which router I used then
(but it definitely wasn't an R7000P). Although 22 -> 22 should work,
even if it did, I'd really advise against doing it. Is there any
SSH-related application which doesn't let you specify a different port?
Any other (good) reason to do it?
jelmew
Feb 18, 2018Initiate
Hi,
