gsbacon11
Feb 14, 2021Aspirant
port forwarding not working HELP!!!
If images are not loading I have attached them in posts below the inital main post!!! Background: I am deploying a simple server that I coded in python which is listening on 192.168.1.2 port 10 whi...
gsbacon11
Images seem to be not working either... just my luck
Image 1 attached
- gsbacon11Feb 14, 2021Aspirant
Image 2 attached
Image 3 attached
- antinodeFeb 14, 2021Guru
For the usual problems with port forwarding, see:
https://community.netgear.com/t5/x/x/m-p/1859106
If your server and client can connect LAN-to-LAN, then you'd seem to
have "3" (and probably 2) covered.I'd worry about "1". What's the IP address of the WAN/Internet
interface on the router? Does it match the "YOUR IP [address]" in the
picture?> Model: R6400|AC1750 Smart WiFi Router
Is that accurate? R6400[v1] or R6400v2? Look for "Model" on the
product label. Firmware version? Connected to what?
