nigelburnett
May 05, 2017Aspirant
Port forwarding not working
Port forwarding table set up identically to Linksys router. Cannot open any port. I have 5 webcams with static Ips each using a unique port. Latest firmware: V1.1.0.32_1.0.1. Cams all work fine with ...
- May 19, 2017
Sorry, I thought I had closed this thread. The problem was that my cameras were still configured the the other router's gateway address. Once I changed the cameras' settings, everything worked. Many thanks to Netgear tech support who spent an hour on the phone to find my problem.
May 05, 2017Guru - Experienced User
Be sure that uPnP is disabled on the router if your using PF configurations.
Besure your ISP Modem doesn't have a built in router. Bridge it if it does.
nigelburnett
uPnmP off for sure. vanilla docsos 3 modem with no router
- FURRYe38May 05, 2017Guru - Experienced User
Should work ok if you have the PF configured correctly.
- nigelburnettMay 05, 2017Aspirant
1 camera5 8195-8195 8195-8195 192.168.0.195 2 camera4 8194-8194 8194-8194 192.168.0.194 3 camera6 8196-8196 8196-8196 192.168.0.196 4 camera1 8191-8191 8191-8191 192.168.0.191 5 camera3 8193-8193 8193-8193 192.168.0.193 Looks good to me. Is it necessary to reserve the ports in the LAN setup? I tried that. The cameras kept losing frames and I still couldn't open the port. So I deleted the reserve table.
- JamesGLMay 18, 2017NETGEAR Employee Retired
Hi nigelburnett,
Can you check the IP address of the router if it is 192.168.0.1 or 192.168.1.1.
