nigelburnett
May 05, 2017Aspirant
Port forwarding not working
Port forwarding table set up identically to Linksys router. Cannot open any port. I have 5 webcams with static Ips each using a unique port. Latest firmware: V1.1.0.32_1.0.1. Cams all work fine with ...
- May 19, 2017
Sorry, I thought I had closed this thread. The problem was that my cameras were still configured the the other router's gateway address. Once I changed the cameras' settings, everything worked. Many thanks to Netgear tech support who spent an hour on the phone to find my problem.
JamesGL
May 18, 2017NETGEAR Employee Retired
Hi nigelburnett,
Can you check the IP address of the router if it is 192.168.0.1 or 192.168.1.1.
nigelburnett
May 19, 2017Aspirant
- FURRYe38May 19, 2017Guru - Experienced User
Glad they helped you figure it out. Enjoy. :smileywink:
