farbodr
May 05, 2019Follower
Port forwarding not working
Nighthawk R8300
Firmware: V1.0.2.130
I've setup port forwarding for two ports on same server. There are services listening on those ports. I can access them using my local IP and port. I've a...
- Aug 17, 2019
Should have thought of this sooner when setting up the FiOS router (192.168.1.1) in bridge mode and the Nighthawk (192.168.1.4) as the primary router...All my devices have a static IP so they are all hard-coded to use my original router's IP for the gateway/router IP (192.168.1.1).
Everything started working once I flipped the IPs so the Nighthawk is set to 192.168.1.1.
schumaku
May 05, 2019Guru - Experienced User
farbodr wrote:
I've setup port forwarding for two ports on same server. There are services listening on those ports. I can access them using my local IP and port. I've attached a screenshot of my config.
Looks OK if the LAN IP is correct, and both 22/TCP and 8888/TCP should be reachable.
farbodr wrote:
When I check the log it looks like the port is being fowarded correctly but notice the port on the incoming.
[LAN access from remote] from 73.64.xxx.yyy:64092 to 192.168.1.35:8888, Sunday, May 05,2019 07:00:55
Nothing wrong, the source port can be any...
MrLinux
Aug 17, 2019Aspirant
I'm in the same boat and I see port forwarded correctly in the logs but it's not actually establishing a connection. I can telnet to it from my box internally, but doesn't work when trying to do the same from a remote host. Logs show the port it's connecting to and the internal server but nothing actually happens.
FWIW, I'm using a FiOS G1100 Modem+Router in bridge mode, passing the traffic to the R7900P.
- MrLinuxAug 17, 2019Aspirant
