ShadowKai
May 20, 2020Aspirant
Port forwarding not working
I have been trying for 2 days now to get any port (specifically 25565) to forward on my router with 0 luck whatsoever. The port is in use by my server, I can access it through ssh, see the port in us...
- May 21, 2020
Got help from the Linux community on this one. Turned out to be a strange firewall issue on the server that was overlooked.
antinode
May 20, 2020Guru
> Model: R7800|Nighthawk X4S AC2600 Wifi Router
Is that accurate? Firmware version? Connected to what?
> [...] I cannot connect to the server over the internet [...]
"cannot" is not a useful problem description. It does not say what
you did. It does not say what happened when you did it. As usual,
showing actual actions (commands) with their actual results (error
messages, LED indicators, ...) can be more helpful than vague
descriptions or interpretations.
https://community.netgear.com/t5/x/x/m-p/1859106
> Attached screenshot for reference
Did you look at what you posted?
- ShadowKaiMay 20, 2020Aspirant
Not sure what happened to the screenshot. It was supposed to be of my port forwarding settings.
And yes, that is my router, Firmware v1.0.2.68.
The only "errors" I am getting are that when I attempt to connect to the server over the internet it times out. When I test to see if the ports are open anywhere it says that they are still closed despite the server being open and running on that port.
- antinodeMay 21, 2020Guru
> [...] The only "errors" I am getting are that when I attempt to
> connect to the server over the internet it times out. [...]"attempt to connect" how, exactly?
> [...] When I test to see if the ports are open anywhere it says that
> they are still closed [...]"test" how, exactly?
> [...] Connected to what?Still wondering.
Did you look at the tests and questions in that thread?
This whole Q&A thing works better when every Q gets an A. Look for
"?".- ShadowKaiMay 21, 2020Aspirant
From the game client on another computer. I can connect via LAN, but not from another computer that is not attached to the same network.
Using port checking websites to verify that they have been opened correctly.
> Still wondering.
An old PC that I am using as a server. It worked fine as a file and web server. It's now being used as a game server for my son to play Minecraft with his friends, but is only working on LAN, his friends cannot connect over the internet to play with him. I've tried remotely using the static IP that was set up as well.
Yea, that didn't really help either. Not really sure why this is so difficult. Just trying to forward a port and make sure it opens. I've done this a bunch of times over the years and never had an issue with it until I bought this router.
