ShadowKai
May 20, 2020Aspirant
Port forwarding not working
I have been trying for 2 days now to get any port (specifically 25565) to forward on my router with 0 luck whatsoever. The port is in use by my server, I can access it through ssh, see the port in us...
- May 21, 2020
Got help from the Linux community on this one. Turned out to be a strange firewall issue on the server that was overlooked.
antinode
May 21, 2020Guru
> >> [...] Connected to what?
> > Still wondering.
> An old PC that I am using as a server. [...]
And its WAN/Internet port?
> Yea, that didn't really help either. [...]
What, exactly, "didn't really help"? (Other than that answer, of
course.)
> showing actual actions (commands) with their actual results (error
> messages, LED indicators, ...) can be more helpful than vague
> descriptions or interpretations.
Which part of "actual" was unclear?
> [...] Not really sure why this is so difficult. [...]
One reason might be that the non-psychics in your audience can't see
what you're doing, and what happens when you do it. Another reason
might be that you seem unable to answer basic questions in a useful way.
> [...] I've done this a bunch of times over the years and never had an
> issue with it until I bought this router.
Sadly, I have no better idea of what you did before than I have of
what you're doing now.
ShadowKai
May 21, 2020Aspirant
