JKLE_Cougar
Oct 02, 2023Aspirant
Port Forwarding Not Working
Hello, I recently purchased this router to replace my old nighthawk router. So far I cannot get port forwarding to work. I am familiar with how port forwarding works since I need it for a few o...
SpaceGentleman
Nov 26, 2023Aspirant
What did you do wrong? I'm experiencing the same issue, and would really like an answer for this.
michaelkenward
Nov 27, 2023Guru - Experienced User
If you don't get an answer from JKLE_Cougar, try posting your own question. If you do, you should tell us more about your network.
You can help people to help you by providing the information suggested in this forum's header:
Subject (Include model number and brief summary)
Model (Recommended - Helps the community give the best answers)
Body (Include additional detail including model version, firmware, OS and environment where relevant.)
They are there for a good reason.
