Aredjay
Nov 02, 2020Aspirant
Port forwarding on R6400v2
so today I was setting up a minecraft server and when i proceeded to port forward it i got this, down below. there is no way to change the external starting point or ending point and no way to set i...
- Nov 04, 2020
Aredjay wrote:
I do think this has something to do with firewall, most likely on the router.
That's just a guess at this point. I don't know about Armor, but the normal NAT firewall in your router won't interfere with the forwarding. Does your router support Armor? If so, did you enable it?
Also, what device is in front of your Netgear router? If it is a gateway, you might also need to add a forwarding rule there (forwarding the port to the Netgear router). If you aren't sure what it is, post the manufacturer and model here.
Other things to look at:
- See if he can "ping" your router using the DDNS name. https://www.hellotech.com/guide/for/how-to-do-a-ping-test-windows-10
- Did you confirm that that the forwarded port was open? There are several websites you can use for that - https://www.canyouseeme.org/ is one.
- Did you double-check that the forwarding destination is going to your minecraft server's local IP address
Aredjay
Nov 03, 2020Aspirant
This is an @ page because no one is responding
plemans FURRYe38 Netduma-Fraser StephenB schumaku Knightkast
Nov 03, 2020Guru - Experienced User
I don't have this particular router, but I haven't had trouble with port forwarding on a wide range of Netgear routers.
The only field that appears grayed out is the internal port range, and that is simply because you checked the option to use external range internally.
What exactly can't you set? Have you entered something in the Service Name field?
What port(s) are you trying to forward?
- AredjayNov 03, 2020Aspirant
Im wondering how to even set it up, when my friend trys to join the server it doesnt work, with the local and public IP
- StephenBNov 03, 2020Guru - Experienced User
The service name is just descriptive - Minecraft should be fine.
The port for Minecraft is 25565.
The local IP address should of course be the local IP address of your minecraft server. Ideally you'd reserve that address -= see page 114 here for instructions on that: https://www.downloads.netgear.com/files/GDC/R6400/R6400_UM_07Aug2015.pdf
Once you've done that, your friend would connect to your public IP address. The problem with that is that your ISP will change your public IP address w/o warning. So you should also register for a free DDNS account (see page 86 of the above reference). Then your friend would connect to the DDNS name, and the DDNS cloud service would resolve that name to your current public IP address.
Could you help me walk through that a bit more? Very confuzed!
also, when i try to connect it says
io.netty.channel.AbstractChannel$AnnotatedConnectException: Connecton timed out
No further info
