Aredjay
Nov 03, 2020Aspirant
Port forwarding on R6400v2
so today I was setting up a minecraft server and when i proceeded to port forward it i got this, down below. there is no way to change the external starting point or ending point and no way to set i...
- Nov 04, 2020
Aredjay wrote:
I do think this has something to do with firewall, most likely on the router.
That's just a guess at this point. I don't know about Armor, but the normal NAT firewall in your router won't interfere with the forwarding. Does your router support Armor? If so, did you enable it?
Also, what device is in front of your Netgear router? If it is a gateway, you might also need to add a forwarding rule there (forwarding the port to the Netgear router). If you aren't sure what it is, post the manufacturer and model here.
Other things to look at:
- See if he can "ping" your router using the DDNS name. https://www.hellotech.com/guide/for/how-to-do-a-ping-test-windows-10
- Did you confirm that that the forwarded port was open? There are several websites you can use for that - https://www.canyouseeme.org/ is one.
- Did you double-check that the forwarding destination is going to your minecraft server's local IP address
Nov 03, 2020Guru - Experienced User
Aredjay wrote:
I really need help with this :/
For the IP reservation, the simplest thing is to use the IP address the server is currently using. When you add a reservation, you should see a device list that includes the server. Just select it, and it should fill in the IP address and the MAC address for you.
For DDNS, you just follow the steps in the manual (page 86) to register and set up an netgear DDNS name. This will be something like adedjay.mynetgear.com (you get to pick the first part).
Aredjay
Hello, do you think it could be something about the security for the netgear router? my cousin was talking about that.
If you do wright back, thank you! i really need help!
