San2022's avatar
San2022
Port forwarding on R7000 not working (fiber & VLAN)
Hi all,    Last weeks I have been puzzling with port forwarding on a R7000. I hope someone can help me out here.    Setup: Fiber (1 Gbit) connected to Optical Network Terminal (ONT) little white...
  • San2022's avatar
    San2022
    Mar 09, 2022
    Hi all,
    Thanks for helping out. I found the solution. The problem was on my NAS (the DNS server on BOND 1 was false). After giving the NAS a static DHCP and on the NAS set this on ' automatic' the connection was resolved.
    After all it was a rookie mistake. However, the learning is that if your port scan gives a state FILTERED or STEALTH, the port is actually open, but the application on the internal LAN is not correctly configured.
    Cheers
