jbuda
Dec 13, 2019Aspirant
Port forwarding on R7000 stopped working
I have a nighthawk R7000 with firmware version V1.0.9.88_10.2.88. I have multiple ports setup for forwarding and it was working just fine until a few days ago. Suddenly I couldn't access anyhting ins...
- Dec 13, 2019
> [...] The WAN listed in the router and my public IP are not identical.
> [...]That would do it. (It's "1" on the list for a reason.) Plug that
address into the form at "https://whois.arin.net/", and get discouraged.> [...] I did notice that the IP for my public IP changed recently [...]
Apparently your ISP moved you onto a CGN router.
> [...] cannot reach the inside of my network using my new public IP.
With another NAT router in the way, that's not amazing.
You could try asking your ISP if you can get (back to having) a
public address (again). They might charge extra for that, if they'll do
it at all. Some ISPs dislike servers for residential customers.
antinode
Dec 13, 2019Guru
> [...] firmware version V1.0.9.88_10.2.88. [...]
Had it been working with that firmware version? V1.0.9.88 is not
universally beloved. If the firmware is suspect, then V1.0.9.42 might
be worth a try.
> [...] Suddenly I couldn't access anyhting inside the network from
> outside the network. [...]
Sounds as if something changed. What kind of "couldn't access"?
Actual error messages?
> [port assignments.png]
Ok. Are the servers at the target LAN IP addresses in those rules?
Are you using Address Reservation, or static addresses, or what?
The usual problems with this stuff are:
1. Wrong external IP address (different from the port-forwarding
router's WAN/Internet IP address). (An intermediate NAT router, for
example, could cause this. Or an ISP using carrier-grade NAT to
conserve IPv4 addresses.)
How are you specifying the router address "from outside the network"?
IP address? DDNS name? Other? Does the IP address of the WAN/Internet
interface on the router (still?) agree with that outside-world address?
2. Bad port-forwarding rule (wrong port(s), wrong target address --
including a wandering target).
Yours look good to me, if the servers are at those addresses.
3. Server not listening on the port-forwarding target system.
I assume that you can contact the servers, from a system on your LAN,
at their LAN IP addresses. Can you also contact the servers, from a
system on your LAN, at the router's WAN/Internet IP address? That test
relies on "NAT loopback" (on the router) working, which it should be.
4. External influences: ISP blocking, other firewalls, ...
Unlikely, especially with a sudden-onset problem.
If you ever do get this stuff working, then, regarding External Port
22: It makes much sense to configure SSH on your local server(s) to use
the default SSH port, 22. However, unless you're looking for a
bombardment of SSH break-in attempts, it makes almost no sense to use
port 22 on your WAN/Internet interface. A rule like the following will,
I claim, save you considerable annoyance:
Protocol External Internal Server IP Address
TCP/UDP 2022 22 192.168.1.9
This does mean that you'd need to add "-p <port>" to all your
outside-world SSH commands, but it's a small price to pay. (Pick any
memorable port which is not needed for some other purpose.)
- jbudaDec 13, 2019Aspirant
Thank you for the informative reply,
I will try going down a firmware version. I had originally been on a version actually higher than my current one and went down a version to test although I can't remember what version that was and I can't locate it on the website. (Was 1.0.10.something).I usually get something akin to "site took too long to respond." or "ERR_CONNECTION_TIMED_OUT" for my webpage.
I assigned the IPs in the router itself so they're reserved for those machines at all times.
I specify which IP by using either my domain (which uses my public IP) or my public IP found when I google "What's my IP"
I can access any of these services from within the network and using the WAN IP.
Thanks for the tip for the external to internal port change to strengthen the network some.
**Edit** Went down to that version and still no dice- antinodeDec 13, 2019Guru
> I will try going down a firmware version. [...]
Or three.
> [...] (Was 1.0.10.something).
V1.0.10.90_10.2.90 apparently was posted and then pulled within a day
or so. Must have been exceptionally bad. (And normally bad is bad
enough to dissatisfy almost everyone.)- jbudaDec 13, 2019Aspirant
Tried going down in versions and it's rejecting some of the older firmware versions. Pretty much anything past v1.0.9.42 and it ain't having it. Gives "error code -2".
Also it appears the thing that changed was I accidentally left on the auto update function and it went to whatever the most up to date firmware was and killed a bunch of settings. Can't seem to undo the damage it did though. Going to try a factory reset now that I'm on 1.0.9.42.
