4IDp8
Nov 09, 2020Aspirant
Port forwarding on r8000 not working
I am trying to open port 25565, but it when i use https://www.canyouseeme.org it says timed out I am trying to make a minecraft server I know little about port forwarding [ Spoiler ]
- Nov 11, 2020
> >I have tried port forwarding inside of the main router using the
> "88.90.##.## address, but it don't seem to workWhat was the actual port-forwarding rule there?
> >Even if the server is up and running while I test it, it says:
> "Connection timed out"It won't work is the server is not on the LAN subnet of the main
router.> IPv4 Address. . . . . . . . . . . : 10.0.0.37
An R8000 would do that if it's configured as a router, and its
WAN/Internet port is connected to another router which is using
"192.168.1.*" for its LAN.> How do I configure it like you said?
> Visit http://netgear.com/support , put in your model number, and look
> for Documentation. Get the User Manual. Read. Look for "Use the
> Router as a Wireless Access Point". [...]> DHCP is enabled:
> [...]The change to WAP mode will stop that.
> Here is the main menu, tell me what you want me to click on and I will
> copy the information and reply with itToo much work. I'd guess that Address Reservation would be under
"DHCP" or "LAN hosts". I'd look for port forwarding under "Port
forwarding".> I don't wanna mess up my parents WIFI or stuff tho
Adding an address reservation or a port-forwarding rule should be
pretty safe. But, safe or not, the main router needs to do the port
forwarding.> Your friends use your (one, only) public IP address ("88.90.##.##")
> to talk to your main router -- the router which is connected to your
> ISP. [...]So, the main router must do the port forwarding.
And the server must be on the main-router LAN subnet. So, directly
connected to the main router, or else connected to the R8000 when the
R8000 is configured as a WAP.
4IDp8
Nov 11, 2020Aspirant
By the way, here is the "telenor router" information
Telenor
Overview
Menu
Router information
Basic information
Reference [something...]
IP address 88.90.##.## <--------[This one is the same as my public ipv4]
Serial number [Somethin else]
Model Zyxel 8702
Uptime 11d 22h 34m
Firmware upgrade
The router has software version 1.00(AAJX.14), which is the latest version available.
antinode
Nov 11, 2020Guru
router.
> DHCP is enabled:
forwarding".
forwarding.
> ISP. [...]
- 4IDp8Nov 12, 2020Aspirant
I fixed the probolem, i took contact with the company Telenor, and they said i were using the wrong IP address for the port forwarding
It works fine now
Anyways, thank you so much fo taking the time to help me.
I really appreciate it!
